fuel pump assembly swap
Old 08-24-2016, 07:27 PM
mang0's Avatar
mang0
mang0 is offline
Default fuel pump assembly swap
getting ready to get a new tank and trying to prepare for the swap. how difficult is it to swap the fuel pump assembly out. The line to the the quick disconnect seems like it would have to be cut and replaced. any tips/tricks/advice would be welcomed.
Old 08-25-2016, 10:17 AM
_LostSoul_'s Avatar
_LostSoul_
_LostSoul_ is offline
Its simple, nothing to it. You'll need new screws for the top plate. I would replace the fuel filter while your in there.
Old 08-25-2016, 10:36 AM
WMX124's Avatar
WMX124
WMX124 is offline
No need to cut anything. The hoses "plug" into the pump assembly with plastic clips. Everything is removable and able to be reassembled.
Service manual recommends new gasket and screws. Pay attention to torqueing sequence of gasket screws at reassembly.
Definitely replace the filter too. Good luck.
Old 08-25-2016, 12:13 PM
mang0's Avatar
mang0
mang0 is offline
thanks for the reassurance, makes me feel better :-)
Old 08-25-2016, 05:53 PM
stilup's Avatar
stilup
stilup is offline
Do the hose upgrade, filter and sock.
Old 08-26-2016, 05:06 AM
mang0's Avatar
mang0
mang0 is offline
ive been reading up on that gates submersible hose upgrade thread. i planning on gathering the parts and will inspect my hoses when i have it out. and decide then if i do the upgrade. Seeing that this is all new territory for me, i may just opt to keep it simple and remove and install the assembly in the new tank. i have 19,000 on the bike
tjmeyer1
03-04-2015 11:54 AM
dwinterringer
12-14-2014 12:49 PM
auburn08
08-25-2013 01:55 AM
lawman1841
Carburetor Related
11-05-2012 01:46 PM
bobbyd3
03-20-2009 05:25 AM
Quick Reply: fuel pump assembly swap
