Annoying idle/throttle issues.
So, to make a long story short, I've been trying to figure out some idling/stuttering issues on my bike.
After ruling out electrical, tuning, fuel, and most others, I decided to take apart the intake. Took off the air cleaner/backing plates. Removed the IAC and gave it a good cleaning. It was pretty gunky. While I was there, I figured I'd remove the TPS. Not much to it.
So I re-assembled everything, started the bike, and now it idles at about 1500 rpm.
Also gettin a TPS open/low efi error.
I've been futzing with it all night. Wires look ok (I don't have a meter), but why the code all of a sudden? Manual says TPS does not need to be adjusted after install. Maybe it was going bad in the first place?
Any suggestions?
Any suggestions?
I don't speak a lot of Harley, but SAE descriptions of codes is universal. Open/Low is an open circuit. Sensor is open, connection to sensor is poor, or a wire is open/broken.
ECM will go to default idle speed when the position sensor is not in place. Did you cram a bunch of grease in the connector when you put it back on? Did you pull a pin slightly from the connector when you removed it to clean it?
I used CRC Throttle body and air intake cleaner to clean the IAC and around.
didn't use any grease or anything. Pulled the sensors out, rubbed them down and re-installed.
I've checked the wires, at least at the connections, and the connectors. Cleaned those, reconnected, etc.
I do have a simple voltage meter that lights up when touching the connector, so at least it's getting power....
Is there a diagnostic procedure in the service manual for the TPS? If so, follow it.
I'm guessing it's just a variable resistor that has two or three check positions with given resistance values for each.
Go buy a proper multi-meter. They're cheap and invaluable for this type of trouble shooting.
Another posibility is low/no voltage at the sensor supply pin (or open ground). Again...meter and service manauls to the rescue.
Good idea. Gonna at least grab a multimeter and see what I can see, or not see...
SoonerSoftail
09-14-2016 07:53 PM
