02 Dyna Cam Chain?
02 Dyna Cam Chain?
I have my 2002 FXD for two years now and just recently heard about the cam chain tensioner issue so this fall I will pull the cover off and see what shape the tensioner is in.
The complication is that I am 67 and live on a pension so money is very TIGHT and this is probably my last bike - couldn't afford to replace it!
If I find the cam chain tensioners are worn, the cheapest alternative would be to just replace the shoes (about $100).
The next step up would be to put on a hydraulic tensioner kit, about $450.
The best alternative would seem to be to convert to S&S timing gear set, about $750.
I don't know what percentage of twin cam engines develop this problem and I don't know if the aftermarket shoes are any better than factory original?
The hydraulic tensioners are more money but I don't know if they have significantly better life expectancy?
Converting to timing gears seems to be the most reliable but the cost is also significant.
Experiences?
Thoughts?
Experiences?
Thoughts?
