Shock adjusting
Higher number is probably stiffer but best way to verify is to look at the detent positions. If the pre-loaded spring is shorter (more compressed), it's stiffer. I always like to start at 3 then play from there.
Edit: I totally missed the actual question, for which I should be censured strongly.
Booey424 (09-22-2016)
As far as actually lowering your bike, you really need to use shorter shocks, unless you have adjustable spring perches, which are rare. The other settings really have more to do with the firmness of the shock and the intended amount of weight being carried, not with ride height.
Ah, I just looked at your attached picture, sorry...
Yes, it looks like they are simply adjustable for preload. As others have already mentioned, this is a setting intended to allow the shock to have it's intended range of motion with a typical weight loading. It won't affect static ride height noticeably, but could slightly affect the height of the bike when you're sitting on it (but not to the degree that longer or shorter shocks would).
Irrespective - set the sag correctly - otherwise, what's the purpose of springs / shocks - simply compress a couple of coils and weld them together
Not that I'm even remotely suggesting it
Ghost
