Clarity in risers?
Clarity on Upper Tree swap?
New to the Dyna world, and found myself in the same predicament as others I've been reading about. I've got a 2012 Street Bob and want to swap out the top tree to use standard type risers. What years will work? Is it only the 08-12 that had the BS integrated set-up? I need to know what years would work on the 2012.
I did read about 06-07 Super Glide.
thanks for the help
thanks for the help
Don't know about other years being interchangeable, but here is a company that makes the top triple tree for the 08 - 12 SB for use with standard risers. They also make risers for use with the stock top triple tree.
http://lonerindustries.com/street-bob.html
LOL... I looked up the stock part numbers, and the tree(s) on the DB from 08-12 are different than any other setup. You could probably order a top tree for either a FXDC, or a newer FXDB.
http://partsfinder.onlinemicrofiche....artsfinder.htm
