Grips
You could try heat; use a twisting motion on the grip as you heat it to try and break it loose. Compressed air shot under the grip may also help break it loose...
A trick for future reference: I never glue the left side grip on, I use blue painters tape. I wrap the tape on the bar near the switch housing where the end of the grip will sit; I add tape and slide the grip on and test fit until the grip is snug on the bar, when the upper and lower switch housing is tightened back up the grip doesn't move.
Makes removing grips a much easier job
Received 2,189 Likes
