Clutch lever vibration! Who has fixed?!
Every HD I've ever had has had a wobbly, vibrating clutch lever. At idle and even on acceleration, my clutch lever shakes like a chihuahua in a blizzard. It's really the only noticeable vibration in my handle bars, and I am tired of riding with one finger on it. Has anyone shimmed theirs, or is there an even easier fix?
Okay I just fixed my front brake lever from rattling. I used a flat washer to go around the bolt that holds lever in place but had to grind the washer thinner so it could fit in between the lever and the master cylinder housing it worked perfectly. My brake system i's not stock I have J B so I had a Allen bolt to fit through the washer. I put the washer on the under side of the lever as to hide it in case it would be visible. I will be doing the same for the clutch which is not a Allen bolt but a pin. Should still work. Hope that helps. The rattling is gone!
