Dual Gauge / Micky Mouse Set-up Quetions
Received 2,189 Likes
Don't know about the LD hardware but Accutronix comes with all the hardware you need.
http://www.ebay.com/itm/Accutronix-G...-/121830569034
thank you!!
ordered-
went in to the dealer and ordered the front and back cushions for the guages and the screws
2 x 67344-97 (FR)
2 x 67345-97 (RR)
4 x 2361 screw
the dealer said to extend just buy the wires and connectors/pins and build what you need... for some reason... this never occurred to me. and folks had already said solder your own...
anyone know what gauge wires are needed? i'm going to go find the wiring diagram for the speedo/tach harness. i reckon i'll need to do the same for the ignition switch.
dealer also recommended Namz: http://www.namzcustomcycleproducts.com/services.html as a source if i wanted to be lazy.
edit: found diagram in service manual...
2 x 67344-97 (FR)
2 x 67345-97 (RR)
4 x 2361 screw
https://www.hdforums.com/forum/dyna-...-question.html
Here's a picture of the stock FXDX bracket and gauges.
