Wife Glide won't start
Got a 2012 Wide Glide with about 8500 miles. When you hit the start switch you get a clicking from the starter solenoid but then the starter just stops. Battery is brand new and fully charged. I rebuilt the starter solenoid and new plunger. No change. If I attach the jump box that will get it just enough juice to kick over and start. But barely. Is the mechanical side of the starter crapped out or what? If you bench test the starter it operates fine but that isn't under a load.
Thanks
Tony
Thanks
Tony
Received 5,388 Likes
Thanks for the quick response. Took the battery in already and had it tested. It's fine. Already checked all the grounds and cleaned the posts. Nothing horrible, just some oxidation. I'm going to try jumping the starter directly, bypassing the switch entirely. At least I got the street glide backup to get some riding in today and tomorrow.
