Removing shift lever off shifter shaft?
10-22-2016, 08:28 PM
Dumb question but, I need to move my shifter lever down a couple splines, can anyone tell me how to remove it off the shifter shaft going into the primary cover? Its on there pretty tight and since its going thru the primary I dont want to start yanking on it and can use a pointer....thanks.
10-22-2016, 08:38 PM
Did you remove the pinch bolt completely?
10-22-2016, 08:46 PM
+QC. The HD Service Manual for your year bike is money well spent.
10-22-2016, 10:10 PM
if u can't figure that out don't ever touch your bike
10-22-2016, 11:57 PM
That's actually the truth TUCCI, the shaft is hollowed out to accept the body of the bolt,, it's not just a pinch fit the bolt has to come out.
10-23-2016, 01:58 AM
Quote:
Originally Posted by
chief08
Like. Fully remove pbolt and spray a little pb blaster or wd40 on it the splines. Gently wiggle it off. Clean off oil. The pbolt holds it in place.
10-23-2016, 02:22 AM
cvaria
Sometimes it helps to tap the tip of a screwdriver into the groove to spread it a little too.
The following 2 users liked this post by Lakerat:
10-23-2016, 03:22 AM
10-23-2016, 08:19 AM
Thats what I figured, just curious before hand. Hey chief, blow me
10-23-2016, 08:34 PM
haha
i'am sure you'll get it
