FXR Aftermarket Triple Tree's
Old 10-23-2016, 05:25 PM
BluBeaSSt's Avatar
BluBeaSSt
BluBeaSSt is offline
Default FXR Aftermarket Triple Tree's
My FXR2 has wide tree's on it, I wanna take it back to a Narrowglide. The FXR2 has the bottom mount headlight so an aftermarket tree set up is easier to find than stock trees for a bottom mount.
Anyone ever ran the Vulcan tree's?
Old 10-24-2016, 10:38 AM
jpace024's Avatar
jpace024
jpace024 is offline
Speed Merchant makes some really nice ones. Mid and Narrow glide.
http://thespeedmerchant.net/product-.../triple-trees/
Old 10-25-2016, 05:39 AM
BluBeaSSt's Avatar
BluBeaSSt
Can't use those tree's with a bottom mount headlight
Old 10-25-2016, 02:03 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
I've been wrong before but it looks like the SM trees are drilled for a headlight block?
Old 10-25-2016, 02:15 PM
Carmell RKC's Avatar
Carmell RKC
Carmell RKC is offline
Buy original parts ?
http://elvisplace.com/
http://fxrrobert.bigcartel.com/
Old 10-25-2016, 02:23 PM
rydercheers's Avatar
rydercheers
rydercheers is offline
You look to be correct to me anyways. The three holes on the bottom tree look to be for a headlight and then the steering stops.
Old 10-26-2016, 08:14 PM
BluBeaSSt's Avatar
BluBeaSSt
I emailed them, they aren't made for a bottom mount light.
Old 10-26-2016, 10:24 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
An OEM "Matching" set of Trees for your FXR2 should be the 2003-earlier Sportster 883 and 1200 "Custom" models. Bottom headlight mount and Padlock Arm/Hole.
If you can drill a hole in the bottom tree, then you should be able to use really any model sportster 2003-earlier
Old 10-28-2016, 09:09 AM
rydercheers
I call bullshit but ok....
Old 10-28-2016, 09:36 AM
rydercheers
Speed Merchant trees with a bottom mount headlight. I don't know who you emailed but they were high when they replied to you cause I've seen a lot of guys run these trees and ditch the eyebrow mount and get a bottom mount headlight.
Quick Reply: FXR Aftermarket Triple Tree's
