Speed Wobbles - "Devil's Dance"
Old 05-30-2007, 03:26 PM
jimmyz's Avatar
jimmyz
jimmyz is offline
Default RE: Speed Wobbles - "Devil's Dance"
Had the same thing happen on my king. I tightened the steering stem nut about 1/2 turn. it worked. thats an old motox trick. JimmyZ
Old 05-30-2007, 03:31 PM
jimmyz's Avatar
jimmyz
jimmyz is offline
Old 05-30-2007, 03:32 PM
jimmyz's Avatar
jimmyz
jimmyz is offline
Sorry!
Old 05-30-2007, 10:36 PM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Tightened the steering nut about 1/3 turn. Went over and double checked the tightness of my front and rear axles, rear adjusters, upper and lower motor mounts, and pinch bolts. Everything was relatively tight and is now "good and tight" I use Loctite red every time I wrench on it and do most all of my own wrenching.
Really want to do the suspension upgrade.Later when I get some extra $$
MV
Old 05-31-2007, 09:55 AM
mile hi's Avatar
mile hi
mile hi is offline
The wobble is caused by the swingarm.Baggers have the same problem. The swingarm is mounted to the back of the transmission, using plastic bushings instead of bearings. The trans/engine is rubber mount, so the flex is transferred to the swing arm. Itsgonna cost. Check out the stabilizers like Sputhe Engineering, couple of others, need to do a search.A fork brace up front helps also. I put a fork brace, Race Tech springs/oilup front, and Progressive Suspension 440 shocks in back. Good shocks in back go a long way to support the back end.I ride the Rockies, many long fast sweepers. The shocks almost eliminate any weaving. Very little wooble left. Does triple digit speeds just fine.
Old 05-31-2007, 10:03 AM
Ratbasturd's Avatar
Ratbasturd
Ratbasturd is offline
Screw that manual, I had the same thing goin on till I started addin air then it went away.
I am runnin just below 40 in the front and 38 in the rear.
I can do smooth highway sweepers at 90 then the wiggle starts comin on.
Old 05-31-2007, 11:16 AM
SUPER01's Avatar
SUPER01
SUPER01 is offline
ORIGINAL: mvinc01
I would like to install 12" Prog. 412 HD's and Prog. springs with SE fork fluid up front. I wonder if that would help cure it?
Sounds like mayby the stock supsension is abit too soft for that kind of riding?
MV
Just put the SE fork oil in a couple weeks ago and it is a little stiffer but not a lot.
Old 06-05-2007, 07:47 PM
Mysterman68's Avatar
Mysterman68
Mysterman68 is offline
3rd Gear
I had the same problem with my 05 WG. I put a fork brace on it and it took care of the problem. Didn't matter if the windshield was on or not.
Ride Safe!!
Old 06-06-2007, 01:19 PM
stbobber's Avatar
stbobber
stbobber is offline
what kind of fork brace?
Old 06-06-2007, 07:22 PM
06dynablack's Avatar
06dynablack
06dynablack is offline
metz tires require lotta air if you want any milage out of it. rear metz 160 you run 48 to 50 psi
Quick Reply: Speed Wobbles - "Devil's Dance"
