Speed Wobbles - "Devil's Dance"
RE: Speed Wobbles - "Devil's Dance"
Could be the pavement, but make sure there is nothing loose in the frontend. Check the pressure in both tires. Also, check for runout and out of round on the tire and rim. You might need to get the front wheel rebalanced too. Not just a static balance, but spin balanced.
if you can go around one turn at 70, but not another (assuming they are the same sort of turn), then other factors have to be considered... and there are a lot of them.
not to discount other posts, but wind coming at just the right angle, or just the right ripple in the road, in combination with the shield and/or higher bars, could be contributing factors (I'm an ape fan, so this isn't coming from one of those "apes are dangerous" guys)
I think you will notice a great improvement in all riding if you upgrade your front and rear suspension - I can't say enough good things about Race Tech springs and their cartridge emulators, for your front end.
I had that problem a couple of weekends ago, no windshield, 16 inchers....first time that has happened. Wide, long turn, worried me for a mintue.
A friend told me to tighten up the 2 bolts down at the bottom of the forks....says his gets loose from time to time and that problem comes up
ORIGINAL: mvinc01
Thanks all for the feedback. Much appreciated. Preasure is good. I checked it at 36 that morning. Tires are brand new ME880's.Wheel balance is good to.
MV
MV
Many, many different things can cause high speed wobble. Biggest pain is that if you went back to that same spot and did the same speed you might not have a wobble at all. I wonder if there's a way to tighten up the fork, or add a steering damper that isn't all huge and ugly? Plus one of those fork braces would probably bea lot of help and not too costly.
Planning on upgrading my suspension all around, and probably adding a fork brace too. As far as air pressure goes, there are about a thousand and one different opinions.
Some of my exp examples are...
The MoCo states in their manual to run 30 up front and 36 out back cold. Up 3 psi for a passenger.
Metz website actualy refferences the manufacture sticker for psi on the frame.
Both the dealer service shop and the Cycle Gear shop where I bought the Mets return my bike after service with 36psi in both.
MV
MV
