Fuel Stabilizer
Truth! SeaFoam stabilizes fuel, controls moisture, cleans injectors and carb jets, and dissolves fuel residue in the system.
I begin adding SeaFoam on my last rides before the bike is prepped for her winter's sleep running it through the fuel system. On the final ride of the season I add the last of the can of SeaFoam and top the tank off fully.
In spring I'll run the tank down as far as possible letting the SeaFoam continue to work its cleaning magic
https://seafoamsales.com/sea-foam-motor-treatment
Received 4,309 Likes
There are several good stabilizers out there. Once you find one that worked for you stay with it. Stabil and Seafoam have been mentioned, both are fine products. I use Startron Ethanol Treatment through out the riding season and at the end of the riding season as a stabilizer. So each to their own.
