What is "too cold" to ride?
Dress right and adjust fluid/lubricant viscosities and there's really no limit beyond comfort and practicality. Probably not a great idea to run an airhead in arctic temps but I doubt it would actually hurt the engine...just run crappy. My first concern after fluids would be plastics getting brittle.
If you have heated gear for those cold days your rides most likely will be more enjoyable. My commute to work is about 40 minutes and the cold sinks in little by little as the minutes pass by. Even with all the layering up I used to do that cold still found its way to my upper torso, I use heated gloves and a vest which help a ton and its a lot more comfy not needing all the layers. Also, a wind screen and full face help a lot, but they are referenced based, not everyone like one or the other or either.
Cold temps shouldn't discourage you from riding, its the potential dangers winter brings that you just need to be more aware of. I have been close to zero, but will only ride as long as there aren't conditions for ice or snow on the road. Those bridges that say they will ice before the roads do, believe them, it's not fun hitting one of them while on the throttle and finding out your traction is gone.
I keep my bike outside most of the year, I have a shed that it goes in but depending on the ground conditions it either has to wait to go in or to come out because of the moisture in the ground. I envy those with a garage! So when it stays out during the winter it has an all-weather cover, which is nice for riding prep time. The cover also allows me to put my trickle charges on the bike seat and have it going while it is covered, nothing sucks the battery life out like the cold.
I live a half mile from the MI/OH line directly below you. Det to me is mid Michigan LOL
Much High that that is Canada "AKA the UP" lol
They are talking big snow the next couple of weeks dress warm and be safe.
Depend on how far you go. But it's sure not safe in bad weather, below freezing or black ice conditions. Bikes are a hobby for most. I am not sure how you can ever learn what to do a Harley if you slide out. In a car, it's no big deal to practice and at the proper speed, no big deal unless someone else ruins your day.
The coldest I'll go is about 25 degrees Fahrenheit. I ride as late as I can here in northern CT. No windshield on my Low Rider. It fogs up a bit, but I have a full face that I wear when it's cold, my father's old leather jacket and chaps that he had for the cold with his old '79 1/2 Low Rider. Nice thick stuff and it works great. My gauntlet gloves are okay for a while before the cold gets through, but that's nothing that reaching down and grabbing the jugs at a stoplight can't fix. I usually winterize the bike when the threat of snow causes the state to put salt on the roads.
