Cam advise.
Cam advise.
Just got a stage 1 , pipe and tuner . And was talking with the dude at the dealer about dropping a cam , he suggested HD 55 or what ever brand id like . That's probably as far as I'd like to go with the motor . So what's my best bang for the buck ?
Received 1,934 Likes
You'll probably want to spend some time researching cams before you decide. Deciding which one you want can be the major part of the process.
Some cams give you more low rpm grunt (torque), others take some grunt away from the low end and spread it out over a wider rpm range enhancing high rpm torque. Some of em will give you a nice old fashioned lopey sound at idle too.
To optimize some cams, you'll want to consider doing a bit of extra head work. Others are more of a simple drop in. There is a lot to choosing a cam.
Study study study is all I can tell you. Talk to a local indy shop too, usually more helpful than the dealer primarily only knows/deals with Harley cams. You're riding style and needs are the two most important thing to consider. Do you want a cam with stump pulling torque down low in the rpm range? Are you more interested in higher rpm riding thus more drawn to hp? Are you simply wanting to join the 100 hp/torque club to brag to your friends? I kid on the last one but everything plays a part in cam selection. Also will this be the end of your performance goals or do you see other items in your future? Several questions to ask yourself. I simply thought I wanted cams in all my bikes. Finally getting around to doing them and talking to a new friend that runs a performance shop (first mistake) I ended up realizing I wanted to do higher comp pistons, mild headwork, and port the throttle body as well as the cams. Will it haul ***, I'm sure. Will it be fun to ride, I'll let you know. Would I have been happy with a simple cam swap, possibly for right cam. Figure all of it out and you'll be happy in the long run and come out financially better then buying a cam just to swap out again later. And on a parting note I will have a set of se259 and set of se255 cams available next week with under 1k miles if you're interested lol.
I'm in the same boat now. I'm considering a cam upgrade for the lopey idle
Most of all but wouldn't mind more power. For me,, I don't short shift but I don't rev the crap out of it either. I keep it between 2600-3000 most of the time. Just putting around I usually shift around 3300 but am not afraid to run it up. So for me I have to find a cam that's strong and efficient in that rpm range with a lopey idle.
No time for slack-jawed bewilderment, we're counting on you, good luck
Proline1969 (01-15-2017)
My Twin Cam FXDF has Andrews 57 cams, headwork and 2:1 pipes. It sounds great - but it doesn't give the same "dopey" "potato potato" sound that my shovelhead does.
Horses for courses.....
Just be aware that no cams for Twin Cam bikes will give you "that" lopey idle or that "Potato Potato" sound.
Take a real good look at the SE 204. Its a drop in with no head work needed and the lift doesn't tax the stock springs. It gives a great lope, similar to the Andrews 57H, (check it out on YouTube), and comes on at about 2800 rpm. Your 6th gear will pull strong at 2800 +, with a 204 installed.
HKMark23 (02-23-2020)
