Sissy Bar for Low Rider S FXDLS
Old 01-25-2017, 09:49 PM
dpgoodness's Avatar
dpgoodness
dpgoodness is offline
Stage IV
Default Sissy Bar for Low Rider S FXDLS
Fellow Riders,
Just picked up a slightly used LRS (From Mancuso Central in Houston) and its sick...however, I'm used to saddle bags on my old Victory CCT, but refuse to go with bags again. I am using a backpack and it aint cutting it.
Searching for Low Rider S specific sissy bars comes with disappointing results. I was wondering what you guys are doing to solve the fix. I am not interested in the detachable, and I would prefer something I could do at home without having to convert a ton of things.
Suggestions?
Old 01-25-2017, 10:59 PM
17FiXxXeR75's Avatar
17FiXxXeR75
17FiXxXeR75 is offline
That's something I've added to my "list" also.
http://store.slimsfabfarm.com/category-s/1823.htm
Old 01-26-2017, 05:53 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,510 Likes on 2,133 Posts
I am well trained in the lost art of "Google"
https://www.revzilla.com/motorcycle/...dyna-2006-2015
http://ginzchoppers.com/products/001a-old-school
Remember you can search for regular low rider or street bob - same *** end for these purposes.
Old 01-26-2017, 10:13 AM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
Google street bob tall boy sissy bar. Mine is detachable, but is for the street bob
Old 01-26-2017, 10:26 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
Bowman Welding has several different bars available for the LRS. They're not quick disconnect and their workmanship is first rate
Here's a 7": http://www.ebay.com/itm/152302504339
And here's a 16": http://www.ebay.com/itm/152114408260
I used a Bowman Welding 16" on my Wide Glide, it was flawlessly manufactured!
Old 01-27-2017, 03:31 AM
Ghost_13's Avatar
Ghost_13
Ghost_13 is offline
Received 7,033 Likes on 2,935 Posts
Originally Posted by dpgoodness
Fellow Riders,
Suggestions?
Don't know what a LR S sissy bar looks like..., but I have a stock bar off a 13 WG (collecting dust) you can have..., if you make it work
Ghost
Old 01-27-2017, 10:59 AM
dpgoodness's Avatar
dpgoodness
Stage IV
Thank you all for the responses.
Looks like Bowman/Top Hand Ventures is here in Houston. Cant get any more perfect. Will check out their local shop.
Old 01-27-2017, 11:18 AM
JoshFXDL's Avatar
JoshFXDL
JoshFXDL is offline
I have the Kuryakyn under seat sissy bar setup, works great.
Old 06-08-2019, 12:07 AM
thisisagame24's Avatar
thisisagame24
thisisagame24 is offline
I know this is an old thread but has any one found a way to get a detachable sissy bar without having to relocate the license plate?
Old 06-08-2019, 05:53 AM
Nickd2689's Avatar
Nickd2689
There isn’t a way. Unfortunately a detachable sissy bar requires dock points, and the dock points mount with the four fender bolts. Since the lights/plate occupy two of those bolts, they have to be moved.
i did fabricate a setup that ran inside the fender and allowed the lights and plate assembly to mount right behind the fender. It only cost me about 8 dollars for flat stock, and about two hours to build and powdercoat.
Quick Reply: Sissy Bar for Low Rider S FXDLS
