Rev Limit What happens?
I am curious what happens when I hit the rev limit I have my set at 5600 and I never make it there cause it starts to really haul *** and I back off
Here is what I have
Twin Cam 88(a) bored to 95cid/1550cc (stock is 88cid/1450cc).
Crane HI4-TC Programmable Ignition.
Mikuni HSR42 Carb.
Harley Davidson Screaming Eagle High Flow air cleaner and breather kit.
Harley Davidson Screaming Eagle SE-204 cams and upgraded cam bearings.
RB Racing LSR "Black Hole" 2-1 exhaust system with RSR Air/Fuel Ratio gauge and Bosch 02 sensor in front head pipe.
Progressive Suspension front springs and Series 412 rear shocks.
Thanks I am just curios
Tony
Here is what I have
Mikuni HSR42 Carb.
Tony
RE: Rev Limit What happens?
ORIGINAL: TonyS
Here is what I have
Mikuni HSR42 Carb.
Tony
Here is what I have
Mikuni HSR42 Carb.
Tony
It cuts off the ignition so the plugs will not fire.
I haven't hit mine yet either but from what i understand it just backs of like you let off the throttle and then wont let you accel any more in that gear, unless you let the rpms come down first. I don't know for sure but this is what happens when if i hit it in my truck and what my dad has explained to me on his 02 wide glide. If any one has a better explanation i would like to hear it as well so im not suprised when it happens
Hey Tony,
I can't realy say because mine is at 6200 with the SE Ignition module, so I've...uhhh eemm...never hit it.
What I did want to say is that your set up sounds really nice. I would also like to add the 95"kit w/Andrews gear drive cams and hi-comp pistons, ported heads, and Race Tech front emulater/springs w/Prog 412's out back too. I currently have Python 2into2 and S&SSuper E. Just feels unfinished. Better than stock though.
MV
MV
Yeah I gotthe heads ported also.. I couldn't pass the deal up 9300.00 for it a 1999 with 7400 miles on it..The guy I bought my bike from has it set at5600 the Crane manual for the ignition says 5600... they are probably just covering their butt..I don't even getthere I get almost there then I back off..I always start thinking...haaa then back off
Tony, 5600 is a very conservative # to set the limiter.
The "stock" valve train will rev up to about 6200 or so, w/o exploding.
What happens w/ the limiter is simply preventing your motor
from exceeding this # by breaking up the ignition.
Protecting your investment.
Mine is set at about 6200. Hit it now and then if I don't shift right.
No tach. Gotta change that.
Ya oughta try it one Day, maybe. Maybe not.
Be careful of course, ride it in your comfort zone.
mud
mud
ORIGINAL: TonyS
Here is what I have
Mikuni HSR42 Carb.
Tony
Here is what I have
Mikuni HSR42 Carb.
Tony
