The chopping continues...
OK, I ordered up some Bondo, rubber sand block, and assorted sandpaper kit (120-4000 grit). Should be here Tuesday by Amazon. I won't hit it with the sander again. Also, got the 5/16-18 tap, same size as original bolt.
Also, did not get the lightbar because I already had some rear flex LEDs from Custom Dynamics that I had pressed on the shock bodies since forever. However, this may not work out anymore because the wires will be exposed. Let me know your lightbar tip and if you know any cheap place to get kellermans or similar.
UPS says Out For Delivery with my Rocket Bob's order!
