The latest with the 117
Nickd,
Oh NO, I hope I didn't come across as being rude by any means.
I was trying to say that the MoCo did it pretty well with the 117" Big Bore kits. Bonus, if done within the correct time frame, it can be warrantied too.
Aftermarket big bore kits will/have always produce bigger numbers.
On the top right hand of the Dyno sheets show STD (Uncorrected) or SAE. (Corrected)
Enjoy!
YB
Enjoy!
YB
Nickd,
Enjoy!
YB
Enjoy!
YB
Anyway, yes I agree 100% with everything you said. Lol I stated that I was "well aware my numbers were a little low" cause I've been talkin this whole time like I have the fastest bike in the world, point is: I'm not delusional lol. Anyway my papers are in my truck which is still at the Harley dealer cause I wanted the bike more than the truck lol. Maybe I'll get the truck next week....or the week after. Anyway, I'll see if my girl can grab em out of my truck tomorrow since she works there.
Nick that's awesome! I'm glad you enjoy the 117. I know I love mine. If your interested in a little more power besides a fine tune change your front sprocket to a 30 tooth. Mine is pulling 110hp and 131tq its a freakin blast to ride. Hell my RG is pissed off now since I always pull the lwrs out and leave her sitting alone. Be safe on it man it will grab you by the boo boo. Burn rubber not your soul. 👍🏻
...to preserve "the 117".....
...finally i read a 3D with many fans of the 117 !!!!! i'm very happy!!
Hoping to help someone, i give you my esperience of 5000 miles (about - 7500 km), particularly for the summer travel.
My 117 got an impressive oil temperature (manometer), so i put on it a fan oil cooler and i'll change the spark plugs with Others more "colder" .....
In this way i hope to keep temperatures low, because otherwise it's a big problem .......
(sorry for my writing...)
Nickd,
Enjoy!
YB
Enjoy!
YB
Yellowbird STD is a different correction factor to SAE. It is not Uncorrected or Actual. I can't remember which but dynojet uses Uncorrected or Actual when that is the case. STD is usually a little higher than SAE.
Cheers,
Surly
Nick get some fuel in it and fast. You will love it as much as I love mine.
Cheers,
Surly
Cheers,
Surly
Surly,
I was alway under the impression that Std, was a Uncorrected SAE was a corrected format of measurement.
You are correct that STD is generally acouple points more. (IIRC about 4-5)
Either way, it's still an awesome upgrade that I feel is well worth the money spent.
Thanks.
YB
I feel you on wanting to tune it yourself. I have done a lot of road tuning with cars and I would only put my car on a dyno to verify my tune, mostly out of pride. Motorcycles are significantly more difficult however because it is almost impossible to view the parameters live and compare to logs after the fact to make adjustments. For that reason I started with an initial dyno tune and will tweak as needed. I have included a copy of my dyno. I do not have the fuel curve with me, but I seen it at the tuner shop. It was almost identical to yours prior to the tune. Once adjusted, it netted the HP/TQ you see below.
