'02 dyna will start in gear.
Received 4,308 Likes
Received 5,388 Likes
My bikes are always in neutral when parked on level ground. I hope. I'm always asride when I go to "light the fire" so it doesn't really matter. Clutch in also. DON'T TRUST THE LITTLE GREEN LAMP, either! It only takes "once..."
I have other bikes that will not crank unless the clutch is pulled.
My 2004 does the same thing. Took Harley a while to get their act together. I am sure if you wanted to, you could get a stand switch and the other necessary parts from Harley to plug and play fix it. If you think you should, do it. I have hit mine one time. I ride other bikes and have hit the starter once going for the horn.
