Oil Cooler Lines
Oil Cooler Lines
I am installing a vertical oil cooler on my Dyna FLD. The HD Kit comes with the oil lines that are pre bent & formed. I was concerned that the top line goes close to the front cylinder and I was wondering if any one knew of a product like steel braiding that would slip over the oil line and still be flexible enough to make all the bends. I would then cover the ends with the hose clamps.
Thanks for any help.
Received 2,189 Likes
Sage wisdom:
i followed the above on my dynas. On my sportster, i used s/s braid lines because the lines are exposed to the road.
gdmt i love that bike
I'd wanted billet clutch cable clamps but none were available in 1 1/2" so I used Drag Specialties #0502-0004 aluminum cast clamps. http://www.dragspecialties.com/produ...umber=05020004
If you are going to go with the hose/clamp upgrade, the #16 fuel injection clamps are part #7051227, they were $1.35 each at NAPA.
The hose is fiber braid reinforced 400 psi Gates transmission oil cooler hose, also from NAPA; 3/8" I.D. I paid $7.20 for 2 feet. You'll need an uber-sharp knife or a hose cutter to cut the hose to length, it's good stuff and much stronger than the fuel line/oil hose that comes with the kit. The hose in the Jagg kit is rated at 50 psi working pressure... no thanks...
Highgrade (02-16-2017)
firehawk6
Oil Archive (no new posts)
06-26-2018 07:03 PM
