GPR stabilizer with FXRT fairing
Im hoping someone will know or have half of an idea on this. I purchased the Russ Wernimont FXRT fairing for my 2017 lowrider and I would like to know if the GPR stabilizer will work on there. Or does the neck bracket interfere with the mount?
I read that Vacant house is the only FXRT fairing that works with the GPR stabilizer but i would rather hear it from someone first hand before i try it myself.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Devine Fab confirmed that their mount will work as well and I'm pretty sure Big Bear Choppers fairing mounts also work with a GPR.
You ned a mount that DOES NOT wrap around the neck if that makes sense. Heres a pic of the Vacant mount with a GPR.
Hi Timhorton,
Some days you find there is not a bolt on solution for everything, As TheSSPirate posted some fit with the GPR some don't, but don't let that stop you as you can always buy someone else's mount that should (might) work or modify the mount you receive with whoevers fairing you decide upon. If you have never fitted aftermarket fiberglass parts you will soon discover there are a multitude of fitment issues that need to be addressed, true with anyone's glass parts. I see you have already bought a Russ Wernimont fairing, Give Russ a call at his shop 951-698-9495 he will have all the answers. Did you buy his mounting kit?
Best Of Luck: Mike
Best Of Luck: Mike
drspencer
04-17-2012 11:49 PM
