Vacuum Petcock 2000 dyna wide
Personally, I would eliminate the vacuum line altogether, and replace the petcock with one of these: http://www.pingelonline.com/Fuel-Val...et-reserve.asp
F86, as always, nailed it That cheap vacuum petcock is one of the first things to go on every carbed HD I've ever had. Install the Pingel and use a vacuum cap on the barb that's on the carb.
Best pricing I've found; it's a bit expensive but the first time you use it you'll understand why If you do eliminate the vacuum petcock get in to the habit of always turning off your fuel after every ride...
Edit: What I posted in your other thread:
Well, if that's what you'd rather do the vacuum hose is part # 26567-99. Should cost $7 or so at the dealer and it's going to be a direct replacement...
You're Right...Corrected and also a different (better ) version below
"yeah Bob, as always, nailed it" (should be "yeah,Bob as always, nailed it")
OR
"yeah Bob, as always, I nailed it" (I think I like that better...btw, then Bob gets "Sloppy Seconds"...and that's OK
OR
