Rear turn signal relocation???
Old 02-23-2017, 10:13 PM
rdrFXDB's Avatar
rdrFXDB
rdrFXDB is offline
6th Gear
Default Rear turn signal relocation???
Hey all
i didn't want to do it, but it's gonna be done. I'm putting bags on the back of my SB. I have a custom fender so what I need help on is my license plate and rear turn signal relocation. The kit off Viking bags doesn't work. I wouldn't be opposed to some kind of recessed lighting in the bags if someone can point me to which turn signals I should buy for that. As always, thanks for the help.
Rich
Old 02-24-2017, 07:31 PM
tpitman's Avatar
tpitman
tpitman is offline
This is the EasyBrackets turn signal relocation kit on my LowRider. What's nice about it is you use the stock turn signal stalks so it doesn't look so cheesy. If you take your time you can pull the plugs off the turn signal wire pins and not have to cut and splice the wires. These bags are Viking Spear w/shock cutout.
Old 02-24-2017, 08:11 PM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
Great bike gear kit. Absolutely love it. Still miss the side mount plate though
Old 02-24-2017, 08:35 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
If you want to be super trick, check out some led bolts. Three or four in each bag would be highly visible. I've used them for different things and been thrilled with the results.
Just one supplier (I've used their warm whites and love them): https://www.oznium.com/led-bolt Also available in other sizes, colors, and profiles from various vendors from ebay to amazon to aliexpress.
Some custom interior lights I mafe using the oznium lights...
Without them:
With them:
Some similar lights from Revival Cycles (lights are called supernova):
Supernova on the far right (ignore the other two):
Old 02-24-2017, 09:34 PM
REW13's Avatar
REW13
REW13 is offline
That's a small bright bulb..
Old 02-24-2017, 09:45 PM
cggorman's Avatar
cggorman
cggorman is offline
If memory serves, it's a 3W diode with a fairly narrow (maybe 45 degree, included) collimator lens. It's a pretty nice light for the price.
ryguylears
03-31-2018 12:29 AM
Bubba Zanetti
11-07-2015 10:09 AM
JT-FXDL
02-04-2013 12:23 PM
gijim
09-16-2010 07:29 AM
ryan.schloesser
05-06-2008 04:54 PM
Quick Reply: Rear turn signal relocation???
