Mag Wheel Swap
I think so too, Only question I would have is the S comes with ABS and the sensor acts as a wheel spacer, one in front and one in rear. I can't see why HD would cut 2 different wheels for the FXDLS and FXDL, but something to think about. May be a dumb point to make, bt you never know with HD. Other than that Im 99% sure they'll fit.
Maybe a dumb question and probably answered before - but will '17 FXDLS mag rims swap right in for my spoked wheels on a '14 FXDB? Going to do the dual disc conversion and have a lead on a set of FXDLS rims with rotors and bearings already installed. Simple swap yes?
Easy swap, changing bearings if needed (ABS vs Non)...hell you could even run ABS equipped wheels on a NON equipped bike if you wanted to...just use reduced length spacers Front-Left and Right-Rear
I understand that, what Im saying is the street bob comes with two normal wheel spacers. The S as you know, has a spacer on the exhaust side and the ABS sensor+ a thinner spacer on the primary side (for the front wheel). My question was, is the width of the ABS module plus the smaller spacer on the S wheels the same width as the street bob spacer on the primary side. I would check but I don't have a micrometer handy, I don't see why they wouldn't fit. The standard FXDL wheels are a straight swap on a FXDB. So if the S wheels are the exact same as the FXDL wheels, then the S wheels will fit fine on the FXDB. The FXDL doesn't come standard with ABS and I don't think the S and DL wheels are cut differently to accommodate for the ABS sensor. Kind of hard to explain but I hope people pick up what I'm putting down.
For ABS, the Front Left "Primary Bearing" side uses a 1pc Combo sensor/spacer which is thinner to accommodate the increased width of the ABS bearing
Wheels are the same (Dimensionally)
Width (ABS 1pc. combo sensor/spacer + ABS bearing) = Width (STD spacer + STD bearing)
205pp is a quality bearing... That's a bearing industry standard #6205-2rs. Every Quality bearing manufacturer makes a 6205-2rs (or their particular # equivalent)
