6 speed conversion
6 speed conversion
00 Dyna Sport
I want a 6 speed gearbox with a higher 6th gear, and wonder what are the alternatives.
1. Can a newer 6 speed HD gearset fit my case and if so what years and what is involved
2. Can I bolt up a completely new HD gearbox to my 00 engine, keeping in mind the .75 swingarm piviot shaft. If so what years
3. I see the builders kit conversions and have read the pros and cons of each brand. If this is the only way Baker it is, but I am hoping for a cheaper stock alternative
00 Dyna Sport
96-00 Dyna, 6 speed gearset, H-D P/N 33100-03A, $2100
99-05 Dyna, Hydraulic Clutch Cover, H-D P/N 38753-04A, $300
: Mike
2017 SE Catalog, Page 84, http://www.boardtrackerharleyonline....ed/2017_SE.pdf
: Mike
: Mike
Any other alternatives?
Would a gearset from a bike that came stock with a 6 speed fit my 5 speed case? There is no shortage of HD 6 speed gearsets, but later models
Does that have to be from a Dyna or would another HD gearset fit my 00 Dyna case?
Fair enough, but rather than buy a retrofit upgrade kit:
Oh, and SE parts are frequently rebranded big-name aftermarket parts.
In 06 on the Dynas was the first year for the factory 6 speed or "cruise drive" 6 speed. Totally new case and gear set design they are not interchangeable with the 5 speed transmission. Primary is different as well.
