Progressive suspension
I'm about to order some 430s for the rear and from what I read, it looks like I should get the standard rate. I also want to order fork springs but I'm not sure what rate I should get on the forks springs. I ride it hard, I'm about 200lbs,and normally solo. Every now and then I'll ride with my 7yr old son. Any suggestions on what spring rate I should get on the front and rear?
sn95bullitt (02-26-2017)
i ended up ordering a set up rear shocks from DK customs instead. i got the bitubo shocks. they were running a special on them, ended up being like 525 shipped. i looked at the ohlins but most of theirs are quite a bit more than i wanted to spend, but they sure did look nice..ill start with the rears for now and upgrade the fork springs some time this summer.
sn95bullitt (03-09-2017)
They look great. I can't wait to hear what you think. I'm thinking of new rears as well and was wondering how DK's are.
11" on the rear ends up being a bit stiff no matter the spring rate due to the limitation of travel once compressed with weight. That and you end up having to lower the front as well to maintain your rake and replacing the kickstand. I've used them and not only is it stiff but you bottom out easily and you lose lean for corners. Maybe look in to monotubes for the front.
