Homemade side mount plate holder
Old 06-02-2007, 12:07 PM
silverbullet2005's Avatar
silverbullet2005
silverbullet2005 is offline
Default Homemade side mount plate holder
I got sick of looking at the bulky license plate setup sitting on the rear fender so I decided to make my own side mount license plate holder. I started with a small 1/8" sheet of aluminum and marked out from the lower left corner the 4x7 plate then marked off the mounting tab that would be used to mount to the shock mount or axle nut. this is very easy to do. from the lower right corner of the plate mount I marked 2 1/2" out and up then from there I marked a 1/2" back in then drew a line to each corner of the plate. this gives the plate mount an angled less bulky look. from there I marked another set of lines on the mounting tab from corner to corner and used the center location as my point to drill for mounting bolt to go through. I cut it out on a band saw and used several different grinders/sanders to round the edges and smooth it up then I used a metal break to bend the mounting tab back but you could use a vise also. once it's done use your license plate as a template to mark the four license plate mounting holes. I used a spray can of Krylon Wrinkle Finish to paint it when I was done. I still need to add a license plate frame with an led light to be legal but for now I think it looks good. Click on the link to see the pictures and diagram of how I made it. what do you think?
http://smg.photobucket.com/albums/v7...0Street%20Bob/
Old 06-02-2007, 12:11 PM
theoldguy's Avatar
theoldguy
theoldguy is offline
Default RE: Homemade side mount plate holder
Dude, that looks good! Only question, isn't the plate supposed to have a light on it? If the light part isn't a law in my state, I may have to steal your idea
Old 06-02-2007, 12:15 PM
Shrug's Avatar
Shrug
Shrug is offline
Nice job; especially with the wrinkle paint.
Custom Dynamics sells a chrome LED-lit license frame for about $35.00. I used it on my side plate.
Old 06-02-2007, 12:16 PM
jackyl's Avatar
jackyl
jackyl is offline
great job on you plate mount. suggestion though, you might want to a a stiffening bead or dartinthe middleof yourbend for stiffness, itwill relief stress on your bend and make it break. just a suggestion. jackyl
Old 06-02-2007, 12:28 PM
silverbullet2005
I am going to go with the Radiantz vertical license plate frame which has 3 led's to illuminate the license plate. it's only $32 shipped from www.meancycles.com here is the link
http://www.meancycles.com/Home.asp?P...mp;CompanyID=0
I thought of adding a center brace but it's not like the plate weighs anything so I don't feel it's an issue, if it does break then I'll make another one and add a center support.
Old 06-30-2008, 07:39 PM
Thor's Avatar
Thor
Thor is offline
Good job! I gotta get the wrinkle black for mine. built beats bought every time&nbsp\\;
Old 06-30-2008, 10:57 PM
wtf6316's Avatar
wtf6316
wtf6316 is offline
Looks good. Whats it look like from the rear?
Jersey Drew
09-13-2014 10:14 PM
dhc
02-24-2014 12:43 PM
JoeGrapes
06-29-2010 04:43 PM
Mike in Oregon
09-02-2009 07:23 AM
dansflhti
06-04-2007 06:12 PM
Quick Reply: Homemade side mount plate holder
