Bleeding Front brakes Help
Old 03-19-2017, 10:23 AM
Vic Williams's Avatar
Vic Williams
Vic Williams is offline
Default Bleeding Front brakes Help
I cant for the love of god. Bleed my front brake after putting in a new piston in the master cylinder. There has to be an easier way.
I have a 2001 lowrider
Old 03-19-2017, 10:45 AM
hwork's Avatar
hwork
hwork is offline
I use a syringe and fill it from the bottom. Just make sure to put a rag or something over the master or it will shoot all over.....
Old 03-19-2017, 10:46 AM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,371 Likes on 2,947 Posts
Use a syringe to "push" fluid from the caliper to the M/C. Should be able to get large syringes from a horse equine saddle & tack store.
Use a clear vinyl tubing to the caliper bleed screw.
"Inject" the new fluid into the caliper's bleeder screw.
Be careful to not overfill your M/C!
Old 03-19-2017, 10:51 AM
Ghost_13's Avatar
Ghost_13
Ghost_13 is offline
Received 6,865 Likes on 2,882 Posts
Or spill brake fluid on any part of the bike
That **** is caustic..., and eats paint / PC like its candy
Ghost
Old 03-19-2017, 10:53 AM
NORTY FLATZ
Yeah, best to cover all surfaces with a garbage bag liner. Don't use cloth as it'll still contact painted surfaces.
Old 03-19-2017, 04:44 PM
Johnnyh14's Avatar
Johnnyh14
Johnnyh14 is offline
Go to Harbor Freight and pick up a Mityvac for $40. It's worth it.
Old 03-19-2017, 05:17 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
gravity bleed. just open the bleeder and let it flow.... just keep filling the reservoir
Old 03-19-2017, 05:45 PM
beanoboy's Avatar
beanoboy
beanoboy is offline
Make sure the pistons at the caliper are moving in and out ! They stick pretty easy but spray with brake cleaner and it should free them up...b.
Old 03-19-2017, 09:35 PM
wkdb's Avatar
wkdb
wkdb is offline
I just did this **** new master, new lines and empty calipers. I alternated tapping the brake lines with a screw driver and pumping the lever till no more bubles came up out of the master, took awhile but it worked.
Old 03-20-2017, 08:17 AM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
Never thought of the whole injecting fluid into the calipers. That's ****in innovative. Good idea whoever thought of it.
Quick Reply: Bleeding Front brakes Help
