Dyna with V-Rod forks?
Old 06-15-2007, 05:47 PM
Cynic's Avatar
Cynic
Cynic is offline
Default Dyna with V-Rod forks?
I'm looking for pics of a 06-07 Dyna with V-Rod forks. Thanks!
Old 06-15-2007, 07:20 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Default RE: Dyna with V-Rod forks?
Now that's a conversion I've never seen. Hope you can find a picture.
Old 06-15-2007, 08:43 PM
Cabo's Avatar
Cabo
Cabo is offline
What are you looking to accomplish with this set up. Sounds interesting.
Old 06-15-2007, 11:05 PM
blueglide88's Avatar
blueglide88
blueglide88 is offline
ORIGINAL: Cabo
I'll bet he is looking to go to dual front disks like the V-Rod has. I saw a post about this somewhere on here before.
Old 06-16-2007, 10:39 AM
waterman7474's Avatar
waterman7474
waterman7474 is offline
are you looking for just the lowers/sliders or the entire forks and front end...?
if your just interested in the lowers/sliders, they are almost exactly the same. the only difference is that the left side has tabs for a second disk and the dust caps are different.
Old 06-16-2007, 10:48 AM
jackyl's Avatar
jackyl
jackyl is offline
the forks are the same or are you talking changing the whole frontend. jackyl
Old 06-16-2007, 10:55 AM
BigJfxdwg's Avatar
BigJfxdwg
BigJfxdwg is offline
If all you want is the dual disks it would be cheaper (and easier probably) to buy the kit to change to duals from Dennis Kirk or J&P.
Old 06-16-2007, 11:29 AM
Cynic's Avatar
Cynic
Cynic is offline
BigJfxdwg
I didn't know there was such a kit on the market. Does it include a factory looking slider withcaliper bosses for the second leg? I'm not a fan of anything decorative just for the sake of it, so I stick with factory parts as much as possible.
I've decided to go with wide glide trees mostly for looks anddual discs for more brakes. Been thinking about this for awhile and have since decided to go lower too. I did some measurementson a Boband a V-Rod side by side at the dealer about a year ago, and if memory serves me right the V-Rods forks are about an 1 1/2" shorter overall. The sliders are also substantially shorter, but can't recall how much now. Anyway, I have it worked out as to how I would go dual discs on the Dyna forks, but just thought after seeing a pic of a Dyna with V-Rod forks maybe I would likethat better.
Another thing I've been tossing around is changing out the Bob's decorative fork seal covers with the plain ones froma V-Rod? Something I've yet to measure to see if it's possible, but it sure looks like a go.
Old 06-16-2007, 11:35 AM
SteelCity's Avatar
SteelCity
SteelCity is offline
If you just want dual disks on a 06 or 07 dyna, i am sure that the disk from a v-rod is a direct fit on there. All it needs is bolting on and then sort out the master cylinder/lines etc. No need to change the forks at all..
Old 06-16-2007, 12:39 PM
mud's Avatar
mud
mud is online now
muderator
Received 8,732 Likes on 2,058 Posts
ORIGINAL: SteelCity
SC, needs a lot more than just bolting on.
mud
Quick Reply: Dyna with V-Rod forks?
