Fram oil filter
Old 10-30-2005, 11:11 PM
Hugo's Avatar
Hugo
Hugo is offline
Default Fram oil filter
A few people that own Super Glides & use the Fram PH6065A chrome oil filter. They buy them at wal-mart. Any opinion about these filters?
Old 10-30-2005, 11:48 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default RE: Fram oil filter
Only opinion I have is to use the HD oil filter that was designed to work properly with the HD engine.
Old 10-31-2005, 12:52 AM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Every filter test site I've looked at slammed the Fram filters as pretty much being junk. There's even a letter floating around by an ex-Fram engineer telling how they pretty much dropped their quality and did away with most of their QA. I wouldn't run a Fram on my Muttin-in-Law's lawn mower.
Here's a paraphrased bit on a Fram filter: The filter has cardboard end caps glued in place. It has a rubber anti-drainback valve that seals the very rough metal backplate to the cardboard end cap. It leaks which lets dirty oil drain back into the oil pan. The bypass valves are plastic, and are often incorrectly molded or finished, which lets them leak dirty oil around the filter element.
Old 10-31-2005, 04:23 PM
T Tommyt's Avatar
T Tommyt
T Tommyt is offline
ORIGINAL: pococj
I pretty much heard or read the same as above But I believe that the How to section of this forum may have some info on the do and don't USE filters
Old 10-31-2005, 05:53 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
ORIGINAL: T Tommyt
ORIGINAL: pococj
You've been peeking...Here it is.. https://www.hdforums.com/m_68181/tm.htm
Old 10-31-2005, 06:09 PM
Terry TK's Avatar
Terry TK
Terry TK is offline
Big Kahuna HDF Member
You can cut corners on a few things with Harleys (like doing your own repairs). Your oil filter or oil is not one of the areas you should be cutting corners.
Terry
Old 10-31-2005, 07:28 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
ORIGINAL: terryt1955
Terry
Hey Terry.....I AGREE!
Old 10-31-2005, 08:20 PM
Hugo's Avatar
Hugo
Hugo is offline
I agree that using any other filter on a harley isn't real smart but people are doing it. The funny thing is that the Fram Chrome filter sells for $16.00 and is made in Germany.
Old 10-31-2005, 09:43 PM
Snarly's Avatar
Snarly
Snarly is offline
ORIGINAL: Hugo
I copied the price of a Harly filter off my bill. Look's like it's cheaper than the Wal-mart. I look at it this way. For a lousy buck or two, I'd rather go to my dealer and give them my business. If you have a good dealer and don't support them, you may be missing out someday. I happen to like my dealer and they treat me likewise.
63798-99A OIL FILTER, CHROME
13.95
0.00
13.95
"frappr for HDforums"
Old 10-31-2005, 10:05 PM
JamieWG's Avatar
JamieWG
JamieWG is offline
Even if the Fram oil filters were free, I wouldn't use them. Do the math - say a HD filter costs $15, if I buy 10 of them, I am good for up to 50,000 miles. $150 for 50,000 miles of riding is cheap insurance.
Quick Reply: Fram oil filter
