My Street-Bob is leaking oil from the AIR Filter
RE: My Street-Bob is leaking oil from the AIR Filter
Only supposed to be 2 1/2 quarts of oil in the engine. If one of the techs overfilled it upon servicing to get it ready for you, it'll leak out the breather tube into the air filter. Check oil level-take some out if needed, clean up air filter and ride er'. Should be fine!
ORIGINAL: jkdavis22
ORIGINAL: L0W R1D3R
Thought that there was supposed to be 3 quarts in the engine.
ORIGINAL: jkdavis22
yeah , ya better check your owners manual again nextoil change cus your about a quart low holmes.
ORIGINAL: L0W R1D3R
ORIGINAL: jkdavis22
wt.
What they said, HD is very generous with that extra half quart of oil in te crankcase. Drain your oil until it reads properly on the dipstick. Start with 1/2 quart.............. I don't know how much you can actually overfill the oil hole.
DougJ
DougJ
