Results from Dyno-tune, SE race tuner
This is a fyi post. Just got back from the shop, after stage II and dyno/race tuned. Thought I would share the info.
Based off of the Dyno jet graphs.
My bike is a 06 Streetbob, TC88-
Stock 1450 Max power = 58.24 Max torque = 66.24
Adding Stage I and Reinhart 2 into 1 Pipes after dyno and race tuner used.
Max power = 73.61 Max torque = 74.05
Adding Stage IIafter dyno and race tuner used.
Max power = 83.48 Max torque = 95.07
Thanks,
Thanks,
RE: Results from Dyno-tune, SE race tuner
The stage 2 for the TC88 includes the SE 203 cams, and the larger bore 3 7/8 inch dia. vs. the stock 3-3/4 inch. And this converts it to a 95"TC from a 88TC.
Still doing some research, I believe the new 96" will give more on the HP, based on the changes, but the bore is still the same. Which they changed the stroke,not the cams.on the new 96.
6165hd
07-28-2007 11:32 PM
