thanks for the info... thats what i put in it , i have an 2003 manual and i did'nt know if it was the same for an 2004... i drained it all out and kinda measured what i drained out. harley had put in about 32 oz.. hmmm
I did fluids a week ago using the Harley 2004 Dyna Service Manual and filled the primary with the amount stated in the manual which was 26 oz. After looking at this post I looked in owners manual that came with the bike and it states in the Table Capacities that the primary holds 26 oz but when you look under primary chaincase lubrication in the same owners manual it states to add 32 oz. Which is right? Wonder how many other numbers are wrong?
I would start at the lower amount of fluid, check dip-stick. If above add, then ride until warmed up. If level is below full just top it off. Some times your refill will be less than capacity. You don't always get all the fluid out when you do a service drain.
