07 superGlide noise
Old 08-08-2007, 12:39 PM
beerman522's Avatar
beerman522
beerman522 is offline
Default 07 superGlide noise
Anyone else have a problem with knocking noise from left side primary area on this New 96 CI engine? I have contacted the dealer twice and am told this noise is "Normal" It is getting louder and it is definately not a normal sound
Old 08-08-2007, 03:15 PM
Skitzer's Avatar
Skitzer
Skitzer is offline
Default RE: 07 superGlide noise
Get a second opinion from a different dealer. That noise is not normal. I have an 07 Super Glide also and have no such noise coming from my left side primary.
Old 08-08-2007, 04:15 PM
detailer03's Avatar
detailer03
detailer03 is offline
I have no noises like that.
Second opinion is best.
Old 08-08-2007, 04:25 PM
narosar's Avatar
narosar
narosar is offline
no such noise from my 07 fxd, best to have someone else look'er over.
Old 08-08-2007, 07:27 PM
TowJam's Avatar
TowJam
TowJam is offline
ORIGINAL: beerman522
Does the sound happen at idle? Does it increase in frequency/intensity as you ride? Do you only hear it when in 5th gear?
Based on your initial description, it sounds like you might have a loose primary chain. In any event, I echo what others have said - you need to have it looked at.
Old 08-08-2007, 08:41 PM
cardboard's Avatar
cardboard
cardboard is offline
My bike makes a noise from the primary side. The dealer said that some of the 07 bikes makes more noise from the auto adjustors.
It seem's to make the noise when the bike is hot or you are gearing down.
I've got about 9800 on my bike with the noise. I'm going back to my Indy builder in 2 weeks and gonna ask him to listen to it. Might git him to take the primay off and look at it even.
Old 08-09-2007, 04:09 AM
black dyna's Avatar
black dyna
black dyna is offline
i had a noise got louder when it got hot .it would do it when ever the cluch was out.standing still and driveing in all gears.would not hear it with cluch in and in gear standind still.it was the race in that bearing in the primeary.5000 miles on the bike.got it back last week no more noise.
07 bike.heard the noise for a long time at the 1000 mile check they said they did not hear anything but i did.at 5000 miles it got reel bad they could not say they didnt hear it.
Old 08-09-2007, 06:30 AM
JBaker421's Avatar
JBaker421
JBaker421 is offline
Big Kahuna HDF Member
Have you seen this thread?
https://www.hdforums.com/m_654370/mpage_58/key_/tm.htm
Old 08-10-2007, 06:56 AM
Psycho's Avatar
Psycho
Psycho is offline
It sounds like the compensating sprocket may be loose, and getting looser.
Get it checked out.
Old 08-10-2007, 07:39 AM
fastfxrs's Avatar
fastfxrs
fastfxrs is offline
I have a high pitched whirring or mabey even a slight squealing noise coming from the primary side. Its always worse when hot. Its most noticable at idle but I can hear it a slower speeds in all gears. It was much worse in the heat in Sturgis and its barely noticable when you first start it up.. I just got back from sturgis and I'm going to my local dealer today to let them have a listen.
Quick Reply: 07 superGlide noise
