Last edit by: IB Advertising
Have a trouble code? Forum members post several methods to clear different types of error codes. Sometimes, error codes can be caused by wires that have rubbed through and are shorting out. Be sure to check your ground connections to ensure it is not a simple fix.
Read the full discussion below to find your trouble codes and reset them.
Identify Trouble Codes and Clear them
This saved me from going to the HD Dealer. All of a sudden my Wide Glide would start normally then for 6 seconds the Engine Check lamp would come on. It would stay off until I restarted. I retrieved the codes, P1353 and P1356, which says I have no combustion in either cyclinder. Which is strange because I have been riding the bike & its getting 45mpg. So I cleared the codes & now we'll see if the codes show back up.
Anyone else see this before?
Here's a link to the same list that Mud posted but in an easier to read .PDF form. Print it out or save it to your computer.
http://www.jbellphotography.com/foru...or%20Codes.pdf
ukupal808@gmail.com (02-20-2022)
Me thinks aftermarket plug wires..
Still runs great, just every now and then (twisting on usually)
it shows engine light for a few seconds, and codes P1356..
