Old 03-16-2015, 03:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Have a trouble code? Forum members post several methods to clear different types of error codes. Sometimes, error codes can be caused by wires that have rubbed through and are shorting out. Be sure to check your ground connections to ensure it is not a simple fix.
Read the full discussion below to find your trouble codes and reset them.
Print Wikipost
Identify Trouble Codes and Clear them
Old 08-10-2007, 09:27 PM
kevenak's Avatar
kevenak
kevenak is offline
Default Identify Trouble Codes and Clear them
Posting this to share my experience.I was getting codes P0563 and U1097. I found that I had agroundwire from lighting accessoriesthat shook loose from my negative ground terminal from the battery. That more than likely caused the trouble codes. I was able to clear them without going to HD.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting
sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should
illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with
the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing
is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back
to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button
in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset
button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part
number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in
and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it
down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control E
The following 2 users liked this post by kevenak:
BobStreetBob (03-21-2016), ukupal808@gmail.com (02-20-2022)
Old 08-28-2007, 11:38 PM
willett58's Avatar
willett58
willett58 is offline
Default RE: Identify Trouble Codes and Clear them
Thank you so much, this is great info and has helped me!
Old 04-17-2008, 10:14 AM
glide05's Avatar
glide05
glide05 is offline
I just wanted to bump this up.
I'm at work and on my way this AM the red key lamp came on.
Don't have any manuals here - but a quick search in the forums led me to this post.
Very helpful - thanks!
Old 08-26-2008, 04:20 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
Thanks, that's exactly what I was looking for. And I forgot that maybe the search function is working again.
Old 08-26-2008, 06:52 PM
mud's Avatar
mud
mud is online now
muderator
Received 8,807 Likes on 2,070 Posts
kev, P0563 and U1097
are not on the list you post above.
I've seen that posting passed around again and again.
Here is the complete list.........
These will also work on the 07 & 08 bikes.
codes).
lighting should illuminate, speedometer needle should sweep its full range and
illuminate. The word diag should then appear.
with the first P flashing.
flashing is the one you are going to check. To move from one letter (module) to the
to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module
[Carbureted])
SP = speedometer
T = tachometer
button in for 5 seconds and release. If there are any DTCs the code will be displayed
or the word none will appear if there are no DTCs. Push the odometer reset button
8 - If DTCs are not to be cleared, Press and release the odometer reset button. Part
pushing in and holding the odometer reset button ( longer than 5 seconds) until
'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch.
Run your bike and shut it down then recheck the DTCs again by repeating steps 1 to
9. If the code is current it will reappear.
9 Press and release the odometer reset button to continue to the next module.
10 Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the
tachometer identifer is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this
proceedure.
"BUS Er" Serial data bus shorted/low/open/high
B1122 Right turn output fault
B1141 Ignition switch open/low
P0131 Front 02 sensor low (lean)
P0132 Engine running rich
P0134 Front 02 sensor open/not responding
P0151 Rear 02 sensor low (lean)
P0152 Rear 02 sensor high (rich)
P0154 Rear 02 sensor open/not responding
P0501 VSS Low Carb
P0501 VSS Low EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P0661 Intake solenoid low/open
P0662 Intake solenoid high/shorted
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain
Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
2006 models with 02 sensors (Dynas)
P0131 Front 02 sensor lean for any length of time
P0151 Rear 02 sensor lean for any length of time
Above codes can also be set if 02 sensor fails.
AFR Air Fuel Ratio
ATS Air Temperature Sensor
BAS Bank Angle Sensor
CCM Cruise Control Module
CKP Crank Position Sensor. The CKP generates an AC signal which is sent to the
ECM where it is used to reference engine position (TDC) and speed. Home position
established by taking readings off the 22 teeth on the alternator rotor.
DTC Diagnostic Trouble Codes
ECM Electronic Control Module. (The Computer) Computes the spark advance for
proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP
sensors) and controls the low-voltage circuits for the ignition coils and injectors. The
dwell time for the ignition coil is also calculated in the microprocessor and is
dependent upon battery voltage. The programmed dwell feature gives adequate
spark at all speeds.
ECT Engine Coolant Temperature. Sensor also controls the cooling fan relay that
provides 12 Vdc to the fans.
EFI Electronic Fuel Injection
EFP Electronic Fuel Pump
ET Engine Temperature sensor
FI Fuel Injectors
FPR Fuel Pressure regulator
IAC Idle Air Control actuator
IAT Intake Air Temperature sensor
ISS Ion Sensing Systemdetonation detection
MAP manifold Absolute Pressure sensor. The MAP sensor monitors the intake
manifold pressure (vacuum) and sends the information to the ECM. The EMC then
adjusts the spark and fuel-timing advance curves for optimum performance.
TP Throttle Position Sensor
VE Volume Efficiency
VSS Vehicle Speed Sensor. Used as an input for idle speed control
The following 3 users liked this post by mud:
ABQ-Jammer (04-02-2018), AKJames (05-05-2018), Tazze (08-11-2019)
Old 08-26-2008, 10:28 PM
ehretja's Avatar
ehretja
ehretja is offline
Does anyone know what might cause b1007 "Ignition Line Over Voltage Instruments".. i'm getting that and my bike will periodly shut off and stall while riding and/ or misfire.
Old 08-27-2008, 10:00 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
you have a pinched wire under you dash, most likely between the tank dash suport brakets and the screws that go into the dash to hold it
Old 08-27-2008, 08:07 PM
snowchaser's Avatar
snowchaser
snowchaser is offline
2nd Gear
I am getting a code of b1154 does anyone know what problem that is for? and would it cause my idle rpm to raise and lower? Thanks in advance.
Old 08-27-2008, 09:01 PM
ehretja's Avatar
ehretja
ehretja is offline
joe...thanks man you're always a huge help...looks like i'll be tearing the dash apart this weekend looking for a pinched wire. Its odd that it all of the sudden occured and didnt have any issues the first 1200 miles. I hope I can identify something and solve it quickly.
Jeff
Old 08-29-2008, 09:07 AM
lloyd67's Avatar
lloyd67
lloyd67 is offline
6th Gear
does this code list apply to my 2002 EFI Road King?
Quick Reply: Identify Trouble Codes and Clear them
