Handlebar risers
Handlebar risers
I just put on Street Bob handlebars on my superglide. Nice bars but I could use them about an inch or so higher. Especially after the tank lift I installed.
Are the stock risers measured from the triple clamp to the bar? Or does it include the material going through the triple clamp?
Any one use taller risers on a Dyna?
Thanks
Mike
06 FXD35
Thanks
Mike
06 FXD35
RE: Handlebar risers
I'm going to put a set of these on: http://www.realhog.com/detail.cfm?mo...oduct_ID=19991
They lift the bars a couple more inches and back a tad ... much simpler than changing bars and cheap ... according to the feedback on here it should be fine with stock cables.
I just put 3" risers on my bob to get an extra inch in height as stock risers are 2". Got some nice domed ones with a bit of an old school look off ebay for around $30 with clamps and bolts (make sure you get coarse thread ones 1/2 x 13). They have individual top clamps so now debating about a new tach from Baron (harley tachometers - a forum sponsor) I got cheap to mount on the bars between the risers - should be a bit less obtrusive than the moco set-up. Sorry no pics yet, but like the height increase though not real noticeable - sorta subtle and easy install as stock cables worked fine and only needed to bend brake line a little.
Chip
Chip
it is just easier to post this than to keep sending it out... still let me know if you need help... yes i know i can not spell... let me know if i need to clearify....
ok... here is what you do:
first decide how all you want to go... pull the stock bolt that feeds up from the bottom of the tree and into the stock handlebar clamp... take that to home depot or the hardware store... get a 1 or 2 in longer HARDENED bolt that matches the same threads and demensions just longer... then pick up a box of fender washers that match the bolt (they should be around the size of a quarter or half dollar)... now take a walk over to plumbing and pick up a piece of chrome piping that matches the circumfrance of the washers (the piping that i used was the kind that is under sinks... thin and chrome, it does not bear weight it is just for looks).... last thing to get is a push chrome cap that fits the pipe. ooh ya and some lock tite
Now how to do it:
pull your bars and pull your stock bar clamps off... find the exact center of the push caps and drill that out to match the circumfrance of the new bolts you will be using... measure out how high you want to raise your bars, then just count out the number of washers it will take to acomplish the lift. after you know the amount of washers it will take measure the stack of washers (goes without saying but make sure both of your stacks have the same amount of washers)
cut your plumbing pipe to match the height of the washers, BEFORE CUTTING, put some packing tape around the area to be cut, this will prevent the chrome from flaking, after both peices are cut file down the rough edges and put it all together (use just a touch of marine grease on the washers to prevent any squeeking... just a touch) mine squeeked a bit but my dads and brothers never made a peep... just tighen it all down and there you go! 3 dollar risers! Here is a crude picture to give you a idea
[IMG]local://upfiles/26534/482C4A6F7F26409F8C7EEE929603C00C.jpg[/IMG]
Now how to do it:
Iām thinking of going with 4 1/2ā tall(DS-290111) Straight Risers
from Drag Specialties if they will work on my 07 FXDB.
If my stock risers are 2ā the extra 2-1/2ā should be just right.
http://www.dragspecialties.com/fatbook/15/268/3870749
