I just installed a "CustomChrome" handle bar control kit with HD chrome switch covers on my '07 bober. Ever since I installed the kit the "Red Key" light stays on. What does this mean? I do not have a security system.
Also there is a pressure switch on the clutch side that I had to drill a hole for in the switch cover but the new clutch lever does not hit the pressure switch. Does anyone know what the switch does? The bike runs fine without the lever hitting it.
Does your speedo and dash have power? I had the same problem with a handle bar install and mine turned out to be a short in the turn signal wires at the switch. Don't know if that'll help you or not...
I had the same problem a few weeks ago. When in installed my back rest and side plates i didn't tuck the turn signal wires back and my rear tire shredded the wire causing a short.
Well thanks for all your responses I finally had to bring into the dealer and they found a short. That taught me to save a buck. $75 later I was out the door and the light was off.
Thanks all.
I've had that happen to me before. It turned out to be the rear turn signal wire came loose from under the fenderand was rubbing on my tire. It was starting to wear through and the key light would come on.
