Engine light on & it is surging!!! I need help!
Old 10-05-2007, 03:52 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Default RE: Engine light on & it is surging!!! I need help!
P0263 Rear Injector Open/Low EFI
It could be a bad connection to the rear injector. Check connector. I've heard several people that found that the harness to the injectors had no service loop, so when the engine rocks in the rubber mounts it pulls on the wires, the outer insulation stretches but the wire does not and breaks causing an open circuit.
Old 10-05-2007, 03:59 PM
WS6 Formula
ORIGINAL: gto frank
what years of bikeshave this system of codes i have a 2006 dyna thank you
ratt196635's post of codes and how to check them is for the 2006 and up model years. There are addition codes for the 07 and 08 bikes that are not listed, but the same principle of checking for the codes is the same.
Old 10-05-2007, 05:06 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
thanks formula and everyone else... I will stop at the stealer on the way home to get a new plug... where is the injecter plug located? i looked in my serv manual and did not see tha tlisted?
Old 10-05-2007, 07:01 PM
WS6 Formula
Check out page 4-17, it shows a top view of the injectors. You can see them on you bike right under the tank looking in from the left side of the bike.
Old 10-05-2007, 08:09 PM
BeavisRules's Avatar
BeavisRules
BeavisRules is offline
ORIGINAL: WS6 Formula
I had the same issue a few months back. The dealer replaced the harness to the injector and it has ran fine ever since.
Old 10-08-2007, 07:56 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
THANKS GUYS!!! ALL FIXED! bad wire going to the rear injector!
Old 10-08-2007, 09:30 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
Thanks for the codes and the procedure to check them!
Glad you got your problem fixed JRK5892. I wonder if the 07 Bobs are prone to this same problem?
Old 06-28-2012, 04:54 PM
FXDP Defender's Avatar
FXDP Defender
FXDP Defender is offline
Stage III
Default Need help???
I have a 2001 FXDP Defender (Police bike) and the engine light is on does anyone know how to check the codes and what the codes mean?? Thanks
paulies 07
08-22-2008 08:18 AM
jeff986301
05-15-2008 08:46 PM
04fatboy04
11
11-07-2007 05:55 PM
Dru
09-27-2007 12:17 AM
md188322
07-26-2007 01:20 PM
Quick Reply: Engine light on & it is surging!!! I need help!
