SHUTS DOWN
SHUTS DOWN
REALY COULD USE SOME HELP HERE. I HAVE A 1999 FXDG WITH S&S SUPER E CARB VH STRAIGHT SHOTS AND SE IGNITION.
WHILE RIDING ON SUNDAY, WENT 23 MILES AND BIKE SHUT OFF AGAIN . WOULD HAVE TO SHUT OFF BIKE RESTART AND WOULD RUN ABOUT 3 MILE INTERVALS AND SHUT OFF. FINALLY MADE IT TO DEALER SUNDAY EVENING WHERE IT IS NOW. HAVE BEEN TO DEALER THREE DAYS IN A ROW AND THEY CANT KEEP BIKE RUNNING EITHER. THEY HAVE TESTED WITH THERE NEW CAM SENSOR NEW CRANK POSITION SENSOR AND NEW IGNITION MODULE AND BIKE STILL WONT STAY RUNNING. THERE ARE NO CODES PRESENT ACCORDING TO THIS TECH.
THERE PASSING THIS ON TO A DIFFERENT TECH TOMORROW (MORE EXPERIENCE) = MORE $$$ . ANY HELP WOULD BE APPRECIATED... SATURDAY 11/03/ PICKED BIKE UP AT DEALER, SAID THE REPLACE BANK ANGLE SENSOR, THAT WAS THE PROBLEM. BIKE CAME OUT FROM SERVICE DEPT. RUNNING . PULLED AWAY FROM DEALER IN TRAFFIC AND BIKE DIED . GOT BIKE RUNNING AGAIN LONG ENOUGH TO PULL BACK INTO DEALER. SHUT OFF AGAIN WHILE WAITING FOR SERVICE WRITER TO COME OUT....WTF IS GOING ON????????
Received 4,309 Likes
RE: SHUTS DOWN
has anybody checked the main circuit breaker? I read where some have deteriated over time to the extent where they get hot shutoff power, cool off, then operate till it heats up and the cycle continues. since your are carbed something appears to be shutting off all power , especially to the ignition.
RE: SHUTS DOWN
first off, quit shouting. We can hear you just fine.
are you sure about this:
REPLACED BATTERY AND FOUND NEGATIVE CABLE ARCHING AGAINST FRAME
unless this is a typo, the negative is supposed to be connected to the frame, the positive is not. Is there any chance that you are correct about it and you have connected the posts wrong? I really doubt it , but that is what jumped out first. I don't think it would do anything besides let the smoke out of the wires. you should check the wires for wear all the way from the sensor to the module.
hope it gets cleared up soon for you.
RE: SHUTS DOWN
This could happen if you connect the + cable first (as you should) and then bump the - terminal against the frame as you're installing the battery in the tray.
I can't say about 1999 models, but the negative cableof my 05 FXDLIsparks slightly whenI connect it, becauseI'm applying power to circuits like the speedo, tach, ECM, and TSSM that don't go through the ignition switch. They are connected directly to the battery through fuses. This assumes you are connecting the battery correctly (connect +cable first, then - cable). The +battery cable will definitely arc if you short out the batteryby grounding it to the frame. The battery could blow and spoil your day. Always make sure to install the red cover on the + terminal to prevent contacting the frame.
Gary
Gary
Ceecee Paul
08-30-2013 01:16 PM
