Miracle Jack Stand - Cheap!
This may not be the "scoop of the century" and some of you may actually have one or something better, but I hd to tell the forum all about my new Jack Stand.
This thing cost $74 bucks on ebay, is sturdy as all get out, and is small enough to allow use in sheds, basments, and cramped garages.
Roll it under your bike, have someone make sure the bike doesn't tip as you jack it up, and voila - your bike can be moved around with the touch of a finger and turn 360 on an axis.
I have put on a few new mods since getting this thing, and it is amazing how much easier working on a bike that is secure and level is.
Here arespecs:
MOTORCYCLE / ATV HYDRAULIC LIFT JACK STAND [/b]
ATV-LIFT-1500[/b]
[/i][/b]
~Product Application~[/i][/b]
This hydraulic motorcycle / ATV lift is ideal for stabilizing and lifting. Allows easy access to maintain or store your equipment.[/i][/b]
~Product Features~[/i][/b]
Foot actuated hydraulic pump allows for easy lifting to position,
**** release for easy lowering,
Rubber grip pads on platform protect your motorcycle/ATV’s frame,
Tubular, quality steel construction,
Includes 2 safety tie down’s to secure your motorcycle/ATV to the lift,
Rolls easily on 3”x1” Steel Wheels (2 mounted to frame & 2 mounted on swivel casters),
4 position safety lock, and
Compact for easy storage.[/ul]
Product Specifications[/i][/b]
Platform size – 14-3/4” W x 13” L
Distance between platforms – 10-1/2”
Lowered Height – 6-1/4”
Raised Height – 16-1/2”
3”x1” Semi-Steel Casters
Capacity – 1500 pounds
Weight – 105 pounds
Material – Tubular Steel
Color – Silver Powder Coat[/ul]
Depending on where you are, shipping is from 15 to 50 bucks. It is a heavy item. I recommend it to all who store their bike for any length of time during winter.
[IMG]local://upfiles/39074/BA67E2D8B53C42D5B06A7A3BFDC1384A.jpg[/IMG]
[IMG]local://upfiles/39074/8EFF2F3F29BE4CB5BE52C29745B70209.jpg[/IMG]
Here arespecs:
ATV-LIFT-1500[/b]
[/i][/b]
Weight – 105 pounds
RE: Miracle Jack Stand - Cheap!
Looks great. What brand is it? I 'googled' and found several brands look somewhat the same. In some earlier threads on jacks , there was much discussion of needing lifting blocks to get aroud some of the lower frame when lifting. This was particularly true of the sears jacks. How about this jack--any problems needing some blocking material??
1 Post
The frame is not symetrical on the bottom.3 points are the same height(from the floor) and the other is about 1 inch closer to the floor. While sitting on your bike, it's the right, rear point.The adapter kit have 3 spacers that clip to the frame(holding them on) and a shorter one for the odd point.
ORIGINAL: pshawtx
How about a Craftsman from Sear for $70.00...
http://www.sears.com/shc/s/p_10153_1...p;keyword=jack
