Reflector Removal With Black Denim
Hey guys....
I know it's been covered, but I just cant find the thread. How have you guys done the reflector removal on your black denim street bobs?? With the denim, I dont want to screw up & any help you could give me would be greatly appreciated.
Thanx
Chap
Thanx
Chap
RE: Reflector Removal With Black Denim
The 2005 Harley Davidson Shop manual says that there is a 3M tape solvent that is made to remove the 3M tape that most HD stick on stuff is put on with. I would think you could get it at any parts store. The manual says spray the solvent on the area where the stick-on is, wait a couple of minutes then peel it off. If it is stubborn a little dental floss or light fishing line behind the item to be removed will help. After the item is removed, use the solvent to get any residue tape off.
These instructions were in the 2005 Touring service manual for removing the badge that is on the rear fender of some of the touring models. I would think it would work for your application.
Hope this helps.
Regards,
Bill
Hope this helps.
Regards,
Bill
Thanks also. I just wonder if the 3M adhesive remover will affect the denim paint in any way? I wonder if Goo B Gone would work also? That stuff works great every other time I had used it. It does leave an "orange/citrus" residue though. That's what I'm worried about affecting the paint.
You may want to try a blow dryer and heat it up nice and warm , then with a piece of dental floss or fishing liine, snag it under the edge and lift the emblem off the tank. The remainder of the attachment tape you should be able to roll off using your finger while it is warm.
Just be carefull here as you lift one end, the other end will dig into the paint, so put a credit card under the opposite end of the emblem to protect the paint. Here's where three hands would be a blessing
Probably anything you use as far as a solvent or the likes will shine the area to a degree where you are working, so try this first.
