* HOW TO * under fifty bux *
Old 04-11-2014, 08:49 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by sg dave
This thread inspired me to polish my fork sliders. Looking to save $500 on the chrome. Will post pic's when I learn how.
There is a very good thread by someone that really took the time and did it right and got great results.
  #2042
Old 04-18-2014, 01:21 AM
Cisco726's Avatar
Cisco726
Cisco726 is offline
Here's one that I saw on YouTube that could be applied here, etching metal with vinegar and a battery. Here's the link to the video-
  #2043
Old 04-20-2014, 05:44 PM
bam87's Avatar
bam87
bam87 is offline
3rd Gear
Originally Posted by SLV
Part two.
The final assembly should look like this. Note that you cannot see the nut on the left side.
IMPORTANT. You want approximately 1/2" of thread protruding from the nut so you will have sufficient threads to install the assembly to the shift lever.
Assembly installed on motorcycle. This is not different than installing a normal shift peg. Use blue Loctite during the installation.
Sooo doing this mod...give a couple of the old heads another thing to complain about...hahaha
  #2044
Old 04-24-2014, 09:56 PM
bl_dg's Avatar
bl_dg
bl_dg is offline
What the heck, I'll post this over here, too.
On my lunch break today, new air cleaner cover bolt:
- take your favorite belt buckle or other item
- dremel the offending bits off the backside
- get an elevator bolt at the home store
- sand blast the backside of the buckle and the bolt
- epoxy the two together
- spray the backside with self-etch primer
- ready to go on the bike
Semper Fi
  #2045
Old 04-25-2014, 03:03 PM
BisbeeDyna's Avatar
BisbeeDyna
BisbeeDyna is offline
Nice.
  #2046
Old 05-16-2014, 09:34 AM
TimBob2010's Avatar
TimBob2010
TimBob2010 is offline
Semper Fi
I am going to have to find a cool Marine Corps Buckle and do this on my bikes! Really cool trick brother! Semper Fi!
  #2047
Old 06-30-2014, 10:13 PM
Dan.1977P's Avatar
Dan.1977P
Dan.1977P is offline
This is a great thread. Thanks for all these ideas
  #2048
Old 07-09-2014, 08:01 AM
JerEasy's Avatar
JerEasy
JerEasy is offline
did this on the wheels on my old Z car. Start with 200 grit wet sandpaper and step down through wet sanding 400-800-1200. Finish with aluminum polish applied VERY liberally and not letting them get dry as you wipe in (buff in with a polishing ball and a drill) They will get pretty black and cruddy. Hose em down and then a coat of wax.
took a long time for 4 wheels, shouldn't take as long on the sliders. But you have to be VERY meticulous.
  #2049
Old 07-13-2014, 03:09 PM
Quadancer's Avatar
Quadancer
Quadancer is offline
A paper bag is 2000 grit I'm told, and I've used that to polish headlights, along with some auto polish (NOT wax). There is also a 3000 grit sanding pad you can buy, but not really necessary since aluminum is soft and easy to work. I use corn starch on a MF rag to remove the bulk of the polish between rubs, and mineral spirits will totally clean it when you're done
DyNaMc (07-22-2018)
  #2050
Old 07-16-2014, 06:39 PM
angeltalin's Avatar
angeltalin
angeltalin is offline
Lots of great DIY and info here
Quick Reply: * HOW TO * under fifty bux *
