* HOW TO * under fifty bux *
#2051
Rear Turn Signal Relocation
Parts Required:
2: L-shaped brakets
4: 3/4 inch long 1/4 bolts and self locking nuts
2: 2 1/5 inch 5/16 bolts
Tools Required:
Stadard socket set
Standard wrench set
Drill and Drill bit set
Awl or straight dental pick
Tape mesure
Marking device (ie; Sharpie Marker)
This is for those who have the stock style plate mount on their rear fender:
Step 1 remove Tail light cover
Step 2 unplug turn signal connectors 2 ea.
Step 3 Remove turn signal connector ends from wires
Step 4 Remove turn signals
Step 5 Remove plate mount
Step 6 Measure and mark mounting locations on inside of plate mount
Step 7 drill holes for 1/4 in bolts
Step 8 mark and drill holes for 5/16 in bolts and for wires
Step 9 install brackets on plate mount
step 10 install turn signals on brackets
step 11 route wires through fender
step 12 re-install plate mount
step 13 re-install connector ends on turnsignal wires
step 14 re-connect turn signal connectors to tail light assy.
step 15 re-install tailight assy
step 16 adjust turnsignals for levelness and desired angle\
Remember to always mesure twice before drilling any holes
2: L-shaped brakets
Tools Required:
Stadard socket set
Standard wrench set
Tape mesure
#2053
I removed the fender side reflectors on my '14 street bob reallyyyy easy yesterday with wd-40, goo gone, and dental floss...
spray some wd-40 on the reflector, then with the dental floss, put it between the fender and the reflector, and pretty much slice it out, VERY easy. That should leave the rubber glued thing in the fender still.
spray the goo gone on that, leave it for 30-45 minutes, then come back and peel it off with your hands. comes off clean and no glue residue on the fender.
I did my forks reflectors, with the whole hair drier and wd 40 way, it took me 10 minutes each and i broke a sweat, and got a little scratch on my forks. The other way was sooo much easier, and no struggle nor hair drier was used
#2054
For the forks I kept breaking floss so I actually slid a white t-shirt in there and they came right off.
#2055
#2056
Superglide factory controls.
I feel like there should be more room between the factory pegs and the shifter or brake. Sometimes when starting from a stop it would be nice to have more room to get my food on the peg without bumping onto the controls. Is there a $50.00 fix for this one. Thanks, John
#2058
#2059
First, thanks for the best thread on any forum !!!
And now, yet another muffler mod thread.
Stock mufflers (2-1) on newer switchbacks and low riders are whisper quiet at idle/cruize. I wanted more sound and don't weld so decided to try playing with stock muffler.
All that's required is your choice of drill, grinder/rasp, a few squirts of high-temp paint and a couple hours.
Drilled a few holes (started with 2, then 4, then more)
Then transformed holes into slots
So far I really like sound. Nothing radical - nicely louder/deeper and more harley but still mostly mellow with a little more bark when twisted. It might be a bit more free-flowing than stock - measured by the hand behind muffler method ... and performance might feel a little flat below ~3,000 rpm??
At some point I will enlarge slots to remove ridges at outside and inside edges. This, SE AC and HD tuner have made a nice difference in bike - I'm calling it stage 1 . Someday I might try making baffle removable so I can remove (and/or replace) wrap. I also might de-cat the head pipe. I'm assuming all of the above will effect sound in some way. At this point though I like the sound as is.
#2060
Any kind of ideas for lighting your license plate with that new side mount. I'm digging the idea but not entirely sure how i could light it.
