Fluid leaking from clutch cable
I noticed a couple of days ago that there is fluid leaking from my clutch cable about midway between the clutch handle and where it goes under the bottom of the bike. There is a rubber boot that covers where the cable connects and swivels. It's leaking there under the boot and running down the cable. It doesn't look like that connection can be tightened in any way. Anyone else seen this problem or know what to do about it? It's an 06 Super Glide.
RE: Fluid leaking from clutch cable
The clutch cable connects to the transmisison end cover so I am wondering if there is a seal that prevents the tranny oil from getting inside the cable, or if there is even tranny oil in the end cover where the clutch actuating lever is. never had my end cover off. I would imagine there is tranny oil in there because the lever that the cable pulls on probably needs lubrication. Like ss377 said, maybe someone overlubed the cable? That rubber boot covers the cable adjustment nuts. What kind of fluid is leaking? I guess that would depend on what kind is in your tranny: could be engine oil or gear oil (Syn3, Formula+, etc)
Received 4,307 Likes
ORIGINAL: YellowHawk
It's more than likely oil that has dripped off the dipstick, or been dripped on it when oil had been put in the bike.
Inside the transmission end cover, lubricant naturally splashes onto the working end of the clutch cable. The lubricant runs down the cable and into the cable sheath, seeking its own level at point of entry. That’s nice, because it’s lubricating half the clutch cable for you!
But you are concerned about oil on the OUTSIDE of the cable sheath. Either an O-ring (cable fittingto trans cover) isn’t sealing properly or your cable sheath is letting some lubricant out (fitting, crimp, age cracks, pinhole damage from debris, whatever.) Not a big deal. Mine seeps out,and I wipe it with a rag when I think of it.
Related servicing tip: every so often, you can disconnect your clutch cable at the lever, detach it from all other places on the machine, and then lay the cable down upon some newspaper on the floor overnight. By morning, the little bit of trapped lubricant had treated the rest of the cable... assuming you have lubricant trapped in there.
YellowHawk
03-13-2016 07:41 PM
n0code
09-02-2010 11:47 PM
