SE ignition control module
Old 02-11-2008, 03:45 PM
RazorFXDB's Avatar
RazorFXDB
RazorFXDB is offline
Default SE ignition control module
A friend of mine has an 05 Sportster 1200C.
He just picked up a SE ignition module and is having some trouble getting it to work.
As far as I can tell, from his description, this is simply a plug and play system.
His bike did not come with the factory security system, however as soon as he hooked upthe SE ICM, the "alarm key"LEDlit up
on his dash. He tells me this is the first time he's seen it lit up. He has nofob. Anyway, the bike will not fire with the ICM
hooked up. If he disconnects it and re-connects the stock set up, the bike fires. He tried to follow the instructions in his owners manual for disarming the security system, but to no avail. As I said, his bikeisn't equipped withthe security system.
Anyone have any experiences like this?
Anyone have any ideas?
I have the factory installed security system, but have never had it engaged. (Always have the fob). Does the security system prevent your plugs from firing? Could the ICM somehow have a security feature built in?
Any and all replies are welcome.
Thanks,
Ray.
Old 02-11-2008, 04:02 PM
hk_shooter's Avatar
hk_shooter
hk_shooter is offline
Default RE: SE ignition control module
I know it disables the fuel pump to keep it from running, not sure what else it would do...
Old 02-11-2008, 04:10 PM
RazorFXDB's Avatar
RazorFXDB
ORIGINAL: hk_shooter
Thanks for the reply ... this is what I'm looking for.
He tells megas isgettinginto thecylinders .. Plugs are wet when he takes 'em out. Which means they aren't firing. Do you think I can rule out the security system?
It would make sense, as hetells me his bikewasn't equipped with the security system.
Old 02-11-2008, 04:34 PM
RazorFXDB's Avatar
RazorFXDB
I found this with a google search. I wonder why the search function on the site didn't work?
Oh well. I'll give buddy this info and see if it helps.
https://www.hdforums.com/m_351892/tm.htm
hk_shooter's Avatar
hk_shooter
ORIGINAL: RazorFXDB
Hmmmmm, fuel in the cylinders? I may be wrong about the pump disable thing, then.
I figured that's usually the easy way to keep anything fuel injected from running. No fuel, no fire.
Maybe it just disables the ignition. Can he hear the pump running?
Old 02-11-2008, 05:23 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: RazorFXDB
Ding, ding. We have a winner.
Sure sounds complicated, but so did coding a new key fob. But it wasn't.
Thanks for the link Razor
imbuhlman
Electrical/Lighting/Alarm
11-16-2016 03:05 PM
Buddy WMC
04-25-2012 12:02 AM
dblcruzin
09-12-2008 04:29 PM
cnielsen4130
04-06-2007 08:09 AM
wideride
01-06-2006 12:21 AM
Quick Reply: SE ignition control module
