air pressure in front tire fxdwg
02-23-2008, 05:44 AM
how much air pressure are ya ll running in 21 in stock front tires? own. man. says same for all dyna front tires short and tall. thanks
02-23-2008, 06:48 AM
RE: air pressure in front tire fxdwg
For 21"
Rider only-front and rear = 30 psi
Rider and passenger, front = 36 psi
Rider and passenger, rear = 40 psi
(from service manual)
Don't forget to check before each ride, just in case the Gremlins poked your tires while you were sleeping.
Hope this helps. Ride safe!!!
02-23-2008, 07:15 AM
Rider only - 30 front and rear???
My manual says 36 rear solo... 40 with wifey. 28/30 front for me.
02-23-2008, 08:24 AM
i use 36psi just a better ride for me
02-23-2008, 01:31 PM
30 psi
02-23-2008, 01:45 PM
Sotck 01 front tire, I run 40lbs. Running less, around 36 I bent my rim.
02-23-2008, 02:00 PM
Quote:
ORIGINAL: Baeseman1
Pretty sure thats what my manual says .
02-23-2008, 03:47 PM
31.5 F
37.5 R
Manual says 30 and 36. I go up a pound and a half cold.
I ride solo only.
TowJam
06-07-2017 03:17 PM
cajun1957a
11-28-2016 05:24 PM
Ramez
02-24-2011 07:00 PM
bogie01
09-23-2008 02:24 AM
wasportster
08-03-2007 10:25 PM
06 ,
2008 ,
air ,
davidson ,
front ,
fxdwg ,
glide ,
harley ,
manual ,
pressure ,
pressures ,
proper ,
psi ,
service ,
tire ,
wide
