aftermmarket headlight bulb for an 07 street bob
RE: aftermmarket headlight bulb for an 07 street bob
I switched to the Sylvania Silverstar...much, much beter than stock. I decided to start with the cheapest remedy and work up form there if I had to.....but I'm very satisfied with the Star and will continue to use, unless I start having burn out issues.
ORIGINAL: Gulfstream
Been there, done that...the Sylvania Silverstars burn out quick, I only got about 4 months out of each (2) that I tried. Best bang for the buck is the Osram 70/60W Rally Bulbs, bright but don't pull too many amps that will fry your wires. Osram also makes the original Silverstar which are good too. They're available from some specialty shops (try google) and there's a vendor on eBay selling them.
http://www.rallylights.com/hella/H4.asp
ORIGINAL: JRK5892
I use a star bulb as well and the fogs i put on under my trees! crazy bright!
got the sylvania and low beam still sucks
new clear lens helps but still not good
maybe anHID conversion?
or put a bigger bucket out front ... much more light ... 7" ...
anyway Matkiwi, got any other pics of your front end with the bigger bucket (and maybe no windshield?) Ive been thinking about getting a bigger light, think the stock light should stay on a sportster, just looks too small IMO
ironically, the only thing i like about the stckwas the brightness LOL but im used to old fls and chops that had lightsakin to riding with a candle.
thanks
blackmopar
ORIGINAL: blackmopar
think thats how you quote someone else
thanks
blackmopar
thanks
blackmopar
I have a 2007 FXDB and went to PIAA H-4 extreme white bulb it was twice as bright than stock. Lasted 4 months and burned high beam. Went to the blue PIAA and it doesn't seem as extreme white that will blind you when it hits big road signs. I try to use low beam during day as high uses more juice and creates more heat. With white light I seen every nook, crack cranny and rock on pavement. With Blue my eyes don't pick up things until my front tire hits them. Most Harley shops carry the PIAA bulb but probably stealerships don't as it is not a OEM Harley part made in TIAWAN/CHINA.
